od Mirda » 30. 09. 2012 19:22
snadne zapojeni
RED - Ignition Power
GREEN - RPM signal
BROWN - Ground Wire closer to ECU
BLACK - Ground Wire farther from ECU than brown wire
PURPLE - Knock Sensor
GREY- Throttle position sensor
YELLOW - Air Flow Signal wire going to ECU
WHITE - Air Flow Signal from AFM/Pressure Sensor
na otazky odpovidam non problem
Naposledy upravil(a)
Mirda dne 21. 02. 2013 14:05, celkem upraveno 1 x.
e36 329turbo, 1.5bar, 12s 0-400m, 8.5:1 JE Piston, Eagle H Rods, ARP, e85, samosvor 2,93, sachs performance+HDS57, Walbro 250lph, 800ccm inj.......
