Body Codes
E3 1968-1977 2500/2800/Bavaria/3.0Si sedans
E6 1971-1974 2002 touring
E9 1968-1975 2800CS/3.0CS/3.0Csi/3.0CSL
E10 1968-1976 2002/2002ti/2002tii
E12 1972-1981 520i/525i/528i/530i/M535i
E20 1974 2002 Turbo
E21 1975-1983 315/316/318/318i/320-6/320i/323i
E23 1977-1986 728i, 730i, 733i, 735i, 745i
E24 1977-1989 628CS, 630CS, 630Csi, 635Csi, M635Csi, L6, M6
E26/1 1979-1980 M1
E28 1981-1987 525i, 528e, 535i, 535iS, M5
E30 1982-1992 318, 318i, 318iS, 320, 320i, 323i, 325e, 325, 325i, 325iS, 325iX, M3 including cabriolet and touring
E31 1990-1999 840Ci, 850i, 850Ci, 850Csi
E32 1986-1994 735i, 740i, 740iL, 750iL
E34 1988-1995 525i, 530i, 535i, M5 including touring
E36 1991-1998 316i, 318i, 318ti, 325i, 325iS, 328i, 328iS, M3, Z3, Z3 coupe, M roadster, M coupe
E38 1994-2001 740i, 740iL, 750iL
E39 1995-2003 528i, 530i, 540i, M5 including touring
E46 1999- 325i, 325Ci, 328i, 328Ci, 330i, 330Ci, M3 including touring
E52 2001- Z8
E53 2000- X5
E60 2004- 530i, 545i,
E65 2002-on 7 Series
Engine Codes
M10: 1.5-, 1.6-, 1.8-, 2.0-liter sohc Four-cylinder
1962-1964 1500 four-door
1964-1966 1600 four-door
1963-1972 1800/ti four-door
1966-1972 2000/ti/tii four-door
1965-1969 E9 2000C/CS coupe
1966-1976 1502/1600/1602/1802/2002 incl. ti/tii/cabriolet/touring/turbo
1977-1983 E21 316/i/318i/320/i
1984-1985 E30 318i
M20: 2.5-, 2.7-liter sohc Six-cylinder (timing belt)
1976-1983 E21 320, 320-6, 323i
1984-1991 E30 323i, 325e, 325i including touring and cabriolet
1992 E30 325iC
1982-1988 E28 528e
1989-1990 E34 525i/touring
1988-1991 E Z1
M30: 2.8-, 3.0-, 3.5-liter sohc six-cylinder
1968-1977 E3 2500/2800/Bavaria/ 3.0Si sedans
1968-1975 E9 2.5CS, 2800CS, 3.0CS/i/L coupes
1975-1981 E12 528i, 530i, M535i
1983-1988 E28 533i, 535i/iS
1989-1993 E34 535i
1976-1989 E24 628Csi, 630CS/I, 633Csi, 635Csi, L6
1977-1987 E23 728/I, 730, 732i, 735i, 745i, L7
1988-1992 E32 735i/iL
M42: 1.8-liter dohc Four-cylinder
1991 E30 318i/iS/iC
1992-1995 E36 318i/iS/ti
1993-1995 E36 318iC
M44: 1.9-liter dohc Four-cylinder
1996-1998 E36 318i/iS/ti
1996-1998 E36 Z3 1.9
M50: 2.5-liter dohc Six-cylinder
1991-1992 E34 525i/touring
1992 E36 325i/iS
M50/TU: 2.5-liter dohc Six-cylinder (single VANOS)
1993-1996 E34 525i/touring
1993-1995 E36 325i/iS/iC
M52: 2.0- 2.5-, 2.8-liter dohc Six-cylinder (single VANOS, OBD-II)
1996-1998 E36 323i/iS/iC
1996-1998 E36 328i/iS/iC
1996-1998 E36 Z3 2.3
1996-1998 E36 Z3 2.8
1997-1999 E39 528i
1999-2000 E46 323i/Ci, 328i/Ci
M54: 2.5, 3.0-liter dohc Six-cylinder (Double VANOS, OBD-II)
2000- E39 530i/touring
2001- E46 325i/Ci, 330i/Ci, including touring and Xi
M60 3.0-, 4.0-liter dohc V8 (OBD-I)
1994-1995 E34 530i, 540i, including touring
1994-1995 E32 740i/iL
1994-1995 E31 840Ci
M62 4.4 Liter V8
M62: 4.4-liter dohc V8 (VANOS OBD-II)
1997- E39 540i/touring
1996- E38 740i/iL/iS
1996-1999 E31 840Ci
M70: 5.0-, 5.4-liter V12 (OBD-I/II)
1988-1995 E32 750iL
1996- E38 750iL
1990-1995 E31 850i/Ci
M88: 3.5-liter dohc Six-cylinder (OBD-I, Motorsport engine)
1988 E28 M5
1983-1989 E24 M635Csi, M6
S14: 2.3-, 2.5-liter dohc Four-cylinder (OBD-I, Motorsport engine)
1987-1991 E30 M3
S38: 3.6-, 3.8-liter dohc Six-cylinder (OBD-I, Motorsport engine)
1991-1993 E34 M5, including touring
S50: 3.0-liter dohc Six-cylinder (VANOS, OBD-I, Motorsport engine)
1995 E36 M3, M3 LTW
S52: 3.2-literdohc Six-cylinder (Double VANOS, OBD-II, Motorsport engine)
1996-1999 E36 M3
1999-2000 E36 M coupe, M roadster
S54: 3.2-liter dohc Six-cylinder (Double VANOS, OBD-II, multiple throttle body Motorsport engine)
2001- E46 M3
2001- E36 M coupe, M roadster
S70 5.6-liter sohc 12-cylinder (OBD-I, Motorsport engine)
1994-1995 850Csi
another thing
they dont list the "new' 4.4 V8, or the "new" V12, they go by a defferent names, and it is double VANOS. you know the one in the 545i or 745i, and 760i respectively.
the 7 series, engine has a new designation too.the 6.0 V12 is called N73, while the 4.5 V8 is called N62
They also said the the S52 is a double VAOS, but im not sure if thats true, casue remember the US market got the 3.2 in the 96 M3, but it was still single VANOS with just 240hp, while europe had 2 different versions, the 285hp, regular M3, and then the 320HP EVO M3 engine.
so im not too sure about those two.
Code Series Years Cars
114/E6 - 1967-1977 1502, 1600, 1602, 1800, 1802, 2000, 2002ti/tii
E10/E12 - 1967-1977 E10 touring/wagon 3-door models, E12 2002tii/turbo
E3 2 1968-1977 2500, 2800, Bavaria, 3.0S/Si, 3.3Li
E9 2 1965-1975 2000CS, 2500CS, 2800CS, 3.0CS, 3.0CSi/L
E12 5 1972-1981 518, 518i, 520, 520i, 535, 525i, 528i, 530i, M535i
E21 3 1975-1983 316, 318i, 320, 320i, 320is
E24 6 1977-1989 628i, 630CS, 630CSi, 633CSi, 635CSi, M635CSi, L6
E26 - 1978-1981 M1
E28 5 1982-1988 518i, 520i, 524td, 525i, 525e, 528e, 533i, 535i, M535i, M5
E30 3 1983-1991 316, 316i, 318i, 318is, 320i, 323i, 324td, 325e, 325i,
325ix, 325is, M3
E31 8 1990-1999 840i, 840Ci, 850i, 850Ci, 850CSi
E32 7 1988-1994 730i, 735i, 735iL, 740i, 740iL, 750iL
E34 5 1988-1996 518i, 520i, 525i, 525ix, 525td, 525tds, 530i, 535i,
540i, M5
E30/Z1 Z1 1989-1991 Z1 convertible
E36 3 1991-1999 316i, 318i, 318is, 320i, 323i, 325i, 325td, 325tds,
328i, 328is, M3
E36/5 3 1991-1999 3 series compact: 318ti, 318tds,
E36/7 Z3 1996-current Z3 Convertible, M Convertible
E36/8 Z3 1996-current Z3 Coupe, M Coupe
E38 7 1995-2001 728i, 730i, 730d, 735i, 740i, 740d, 740iL, 750i, 750iL,
L7
E39 5 1997-2004 520i, 523i, 535tds, 528i, 530d, 535i, 540i, M5
E46 3 1999-current 318i, 318Ci, 325iT, 325ti, 323i, 323Ci, 328i, 328Ci,
320d, 330i, 330Ci, 330d, 330dSE, M3
E52 Z8 2000-2003 Z8
E53 X5 2000-current 3.0i, 3.0d, 4.4i, 4.6is,
E60 5 2004-current 5 series sedan models
E61 5 2004-current 5 series touring models
E63 6 2004-current New 6 series
E65 7 2002-current 745i, 750i
E66 7 2002-current 745Li, 760Li (long wheel base E65)
E81 1 2004-current New 1 series
E83 X3 2004-current New small SAV, the X3
E85 Z4 2003-current Z4 2.5i and 3.0i roadster
In the years ahead, we may see...
E55 X7 ?? Larger X5, the X7 is on hold for now
E85/2 Z 2004 Possible Z5 coupe
E90 3 2006/? Next gen 3er
Jaký kokotiny já takym nenajdu
